ASA in front of UC, VPN spa525
Answered Question
Feb 24th, 2010
If the ASA5505 sits in front and manages the data vlan and the UC manages the voice do I need to just manually set the settings in network VPN for the firewall. I'm clueless and can't find much documentation on how it works.I believe option 150 will be in the dhcp scope lf the UC so will the 525 pick it up or does it need to be manually set?
Thanks Stephanie
Correct Answer by Steven Smith about 6 years 8 months ago
The phone should be manually be setup to use the option 150.
You can find out hot to setup the phone to use SSL VPN from here.
Overall Rating: 5 (1 ratings)
