02-24-2010 02:33 PM - edited 03-11-2019 10:14 AM
I am trying to resurrect an older firewall for a project. It is a Pix 515e. I do not have the passwords, so I am trying to do a recovery. I do not seem to be able to get the Ethernet ports on the firewall to intitialize. I have the pix connect to a computer. The console port is connected to the serial pc port and I am at the monitor> port. I have a cross-over ethernet cable attached to Pix E0 and the PC Ethernet interface. At the prompt, monitor> I type interface 0, it comes back with...
Ethernet auto negotiation timed out.
Ethernet port 0 could not be initialized.
Any ideas on what is going on? I actually have 2 pix 515's doing the same thing. The pc Ethernet port is known good.
Thoughts?? Thank you in advance.
02-24-2010 02:57 PM
Hardcode the speed of on the PIX 100full and see if that helps.
Have you tried the other interfaces in the PIX? Did you try to add a switch or hub between the PIX and the PC?
-KS
02-24-2010 03:20 PM
Thank you for your response.
I cannot get into the Cisco pix config far enough to set the speed. The enable password is what I am missing.
I have tried pix E0 and E1, both.
I have not put a switch or hub inbetween, but then again it should not require it.
Again, thank you. Anyone else have any suggestions on why the pix ethernets will not initialize. It has to be something stupid I am missing, or could be hardware.
Thanks in advance...
02-24-2010 03:36 PM
I would certainly try a hub or switch in the middle which will help the interface auto negotiate.
If that fails then you have a hardware issue.
-KS
02-24-2010 03:47 PM
I will try the hub/switch in between to fix or eliminate the variable. Thank you.
