SSL VPN on SPA525G
Feb 24th, 2010
do you have to configure something special in CCA so that one of my spa525G phone's, currently connected in HQ, can be used as remote worker's phone?
Are all the spa525G phones enabled by default for remote working when running the Phone VPN Setup Wizard or not?
Peter.
peter.van.passel Wed, 02/24/2010 - 15:48
Normally when you click on Phone VPN Setup Wizard, you should be able to see a list of spa525G phones, this is not the case.
I see immediately the SSL VPN window, without the possibility to select the phones.
I'm using CCA 2.2 and UC 500 v8.0
Peter.
Marcos Hernandez Thu, 02/25/2010 - 18:39
Did the phones upgrade correctly? Is the SSL VPN server configured with the static IP and all that?
