Conferencing resource on 2811
Feb 24th, 2010
Ok need to verify this one thanks..
Setup - CUCM 6.1 at Main Site. 2811 gateway (1 x 30 channel pri) at remote site. Link between both is small mpls pipe.
Remote site want to do conferencing but not use bandwidth across the Wan.
Can i setup the 2811 as a hardware resource for the remote site so that the 2811 gateway uses its dsp resources to handle the conf call.
If so how many conf calls can i do maxmum. I read that i can do 6 per bridge. So is that 6 max per conf call?
Anything else i need to be aware of for this?
Taff
Jaime Valencia Wed, 02/24/2010 - 17:48
The best practice is exactly that, resources as close as possible to the ones who will use them.
Just configure the MRGLs properly and they will use their resources when pressing conference or doing meet-me
I already covered all the "how many and how much" last week on this post
https://supportforums.cisco.com/message/3022308#3022308
It's exactly the same info you can use.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
