CCM OUTBOUND CALLS ISSUES
Feb 24th, 2010
Hi pros,
             A remote cm at a branch is able to receive calls, but cannot call out. All outbound calls get a busy tone. Strange thing, The same cm has a fxs card with two analog phones attached. These phone are able to receive calls,but cannot make out going calls as well!!
flash:c2801-spservicesk9-mz.124-9.T7.bin --> image
Cisco 2801 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FTX1208W0KF
2 FastEthernet interfaces
1 terminal line
4 Voice FXS interfaces
1 DSP, 8 Voice resources
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
126976K bytes of ATA CompactFlash (Read/Write)
#sho ephone phone-load
DeviceName        CurrentPhoneload       PreviousPhoneload      LastReset
SEP001D45959959    SCCP11.8-2-2SR3S       SCCP11.8-2-2SR3S      Reset-Reset
SEP001DA23EDA3B    SCCP11.8-2-2SR4S       SCCP11.8-2-2SR4S      Initialized
Directory of flash:/
    1  -rw-    27944864  Feb 20 2008 14:20:02 -08:00  c2801-spservicesk9-mz.124-9.T7.bin
    2  -rw-        1821  Feb 20 2008 14:40:52 -08:00  sdmconfig-2801.cfg
    3  -rw-     6036480  Feb 20 2008 14:41:32 -08:00  sdm.tar
    4  -rw-      861696  Feb 20 2008 14:41:52 -08:00  es.tar
    5  -rw-     1164288  Feb 20 2008 14:42:16 -08:00  common.tar
    6  -rw-        1038  Feb 20 2008 14:42:38 -08:00  home.shtml
    7  -rw-      113152  Feb 20 2008 14:42:56 -08:00  home.tar
    8  -rw-     1697952  Feb 20 2008 14:43:30 -08:00  securedesktop-ios-3.1.1.45-k9.pkg
    9  -rw-      416354  Feb 20 2008 14:43:56 -08:00  sslclient-win-1.1.3.173.pkg
   10  -rw-      214561  Feb 23 2010 08:47:16 -08:00  crashinfo_20100223-164717
129748992 bytes total (91275264 bytes free)
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$VKuA$bDZPvyGGc0S01DVm.g7LO.
no aaa new-model
resource policy
memory-size iomem 10
clock timezone PST -8
clock summer-time PDT recurring
ip cef
no ip dhcp use vrf connected
voice-card 0
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
h323
  no telephony-service ccm-compatible
sip
  rel1xx disable
  no call service stop
voice class codec 1
codec preference 1 g729r8
dial-control-mib retain-timer 30
interface FastEthernet0/0
description  Default VLAN
ip address 10.x.x.2 255.255.255.0
ip nbar protocol-discovery
duplex auto
speed auto
interface Service-Engine0/1
ip unnumbered FastEthernet0/0
service-module ip address 10.x.x.3 255.255.255.0
service-module ip default-gateway 10.x.x.1
interface FastEthernet0/1
ip address dhcp
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.x.x.1
ip route 10.x.x.3 255.255.255.255 Service-Engine0/1
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
tftp-server flash:CP7905080001SCCP051117A.sbin
tftp-server flash:CP7912080001SCCP051117A.sbin
control-plane
voice-port 0/0/0
echo-cancel coverage 32
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
sccp local FastEthernet0/0
sccp ccm 10.x.x.2 identifier 10
sccp
sccp ccm group 999
associate ccm 10 priority 1
associate profile 1 register mtp123456792012
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 3
associate application SCCP
dial-peer cor custom
name 1800
name 1866
name 1877
name LocalCall
name 1888
name no-restrict
name Operator
dial-peer cor list Toll-Restrict
member 1800
member 1866
member 1877
member LocalCall
member 1888
member Operator
dial-peer cor list Call1800
member 1800
dial-peer cor list Call1866
member 1866
dial-peer cor list Call1877
member 1877
dial-peer cor list CallLocal
member LocalCall
dial-peer cor list Call1888
member 1888
dial-peer cor list no-restriction
member no-restrict
dial-peer cor list CallOperator
member Operator
dial-peer voice 200 voip
corlist outgoing no-restriction
description CalPri
max-conn 8
destination-pattern .T
session target ipv4:10.x.x.x
dtmf-relay cisco-rtp
playout-delay nominal 250
playout-delay mode fixed
fax rate 7200
ip qos dscp cs5 media
no vad
dial-peer voice 201 voip
corlist outgoing Call1800
huntstop
max-conn 3
destination-pattern 1800.......T
dtmf-relay h245-alphanumeric
playout-delay nominal 200
fax rate 7200
no vad
dial-peer voice 100 pots
huntstop
destination-pattern xxxxxxx
port 0/0/0
dial-peer voice 103 pots
huntstop
port 0/0/2
dial-peer voice 301 voip
dial-peer voice 302 voip
corlist outgoing Call1866
destination-pattern 1866.......T
dial-peer voice 303 voip
corlist outgoing Call1877
destination-pattern 1877.......T
session target ipv4:x.x.x.x
dial-peer voice 304 voip
corlist outgoing CallLocal
destination-pattern [2-9]......T
dial-peer voice 305 voip
corlist outgoing Call1888
destination-pattern 1888.......T
dial-peer voice 2000 voip
destination-pattern 2000
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 202 voip
dial-peer voice 203 voip
dial-peer voice 204 voip
dial-peer voice 306 voip
corlist outgoing CallOperator
destination-pattern 0$
telephony-service
load 7912 CP7912060000SCCP050124A
max-ephones 24
max-dn 120
ip source-address 10.x.x.xport 2000
timeouts interdigit 3
system message xxxxx
sdspfarm units 2
sdspfarm transcode sessions 2
sdspfarm tag 1 mtp123456792012
voicemail 2000
max-conferences 0 gain -6
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern .T
create cnf-files version-stamp 7960 Feb 23 2010 09:08:04
ephone-dn  4
number xxx
call-forward busy 2000
call-forward noan 2000 timeout 20
ephone-dn  5
number xxxx
call-forward all xxx
ephone-dn  110
number 8001..........
mwi off
ephone-dn  111
number 8000..........
mwi on
ephone  1
mac-address 0014.1C48.D665
ephone  2
mac-address 001D.4595.C4DD
ephone  3
mac-address 001D.4595.C476
ephone  4
mac-address 001D.4595.9959
button  1:4
ephone  5
mac-address 001D.A23E.DA3B
type 7912
button  1:5
ephone  7
mac-address 001D.4595.C507
ephone  8
mac-address 001A.2FBE.A124
Thanks any ideas is more than welcome!
Jean Paul
markbatts Thu, 02/25/2010 - 04:06
I had a look at the config and am abit confused.You don't seem to have any local breakout, could you explain in more detail how calls should come in and go out of the Callmanager or is it Callmanager Express?
cheers
Mark
Jean Paul Enerst Fri, 02/26/2010 - 08:11
This is call manager Express, all outbound calls will use the following dial-peer
description CalPri
max-conn 8
fax rate 7200
no vad
jaschulz Fri, 02/26/2010 - 10:14
Hello Jean,
Could you tell me what the session target ipv4:10.x.x.x is?
Jean Paul Enerst Fri, 02/26/2010 - 12:54
It is the IP address of our PRI wich is connected to the PSTN!! There is full IP connectivity between remote CME router and the PRI router; therefore, the session target of the outbound interface is NOT THE ISSUE.
Thank you for your help,
Jean Paul En.
jaschulz Fri, 02/26/2010 - 13:10
Ok,
Yes I didn't think it was the issue, just trying to get a picture of your topology. So you are sending everything from the CME to an egress gateway.
This adds another layer here, could you get a copy of the config on that gateway? As well as verify those PRI's are up and debug voice cc inout from the CME?
Jay
Jean Paul Enerst Fri, 02/26/2010 - 17:28
The PRI configuration is fine as well as well as we have other remote conntected to the same with no issue. And the remote that we are hing issue with was working up to last Sunday. We have taken the config of the remote, changed the IP at both side(PRI and test router), added it to a test router in our HQ. Everything works fine. This test told us that the remote router is faulty, but how come it still receive calls?
