Tommer Catlin Thu, 02/25/2010 - 07:07
  • Green, 3000 points or more
You cant use the CallManager DB for the search in CUPS.  if you have to use an LDAP source such as AD
amarmn1975 Thu, 02/25/2010 - 07:13
Tommer Catlin Thu, 02/25/2010 - 07:15
You can.  The trick is to make their usernames in CUCM match in AD and vice versa.  Also, their phone numbers should match if at all possible.
So ideally, if you have AD, if you can.. would be to sync CUCM with LDAP (AD) and then point the CUPS to the same LDAP source.  Then everything will match.
Tommer Catlin Thu, 02/25/2010 - 07:25
sorry, I didnt make the rules.  CUPS requires an LDAP source and you can not use the CUCM directory.    If you have no LDAP source, CUPC can not use IM or search the directory.  Only works for the RCC and click to call then
Tommer Catlin Thu, 02/25/2010 - 07:49
My pleasure!
In the future, it would make sense to have the user created in AD *first*.  Then use CUCM to LDAP integrate and sync.   Granted, sometimes, this is not possible because of different scenarios.
William Bell Thu, 02/25/2010 - 07:53
  • Purple, 4500 points or more
To accomplish what you want is not really all that difficult but it is a manual (or scripted) process.  Essentially, you will need to export your endusers from the CUCM to a text file.  You can do this using the AXL/SOAP interface or you can leverage BAT export.  I am guessing the latter would be more suited to your needs.
Then you will need to normalize the data that is exported to line up with a CSV format that can be used by an AD import tool or shell (i.e. powershell) script.  At a minimum you will need the first name, last name, userID, telephone number.  An e-mail alias may also be needed depending on what you are doing.
If you are unfamiliar with how to import records into AD, then I suggest you take a look at this:
http://technet.microsoft.com/en-us/library/bb727091.aspx
You will also want to consider your OU structure when start going down this road.  I also recommend that you look at this as a stop gap measure.  Your strategic objective should basically be to import/normalize the data for users in AD and CUCM.  Once you do this, then you should transition CUCM to using DirSync.  The eventual goal would be to have AD be the root for all user provisioning.  If you can get there, then your CUCM and CUPS server will always be in-sync since they would both be leveraging your AD environment.
Now, I am assuming based on this thread that your AD environment doesn't already contain the user IDs that you are leveraging in the CUCM.  This would only be the case if your AD is greenfield.  If your users have user IDs in AD and they have CUCM IDs as well, then you will need to take some additional measures to match and normalize the data so that (a) you avoid unnecessary duplication and (b) you avoid overwriting or deleting a user ID that you may be using. You also may have extension and device associations in CUCM that you want to keep.  The worse case is that you DO have users using both AD and CUCM and you want to change CUCM to use the AD user IDs.  In this case you still need to export the users.  Identify the CUCM-User_to_AD-User relationship, update your userIDs as stored in the CUCM export file.  Then you can use this file either to create new CUCM users that match their AD equivalent IDs OR do a DirSync (which deletes the old CUCM-User) and then a bulk update to re-establish device associations.  This can get quite involved and there are plenty of variables that come into play that I can't account for in this thread.
If you are comfortable with AD, BAT, DirSync, etc. then you should be able to accomplish what you need with proper planning.  If you are not comfortable with these topics, then I recommend you consider finding someone who is to assist.
HTH.
Bill
Tommer Catlin Thu, 02/25/2010 - 08:06
If you are use Unity as Voicemail only, you can use this AD.   It does not matter what AD you use, it just has to be an LDAP source.  If you have an Unity Voicemail only setup, you can use this as well.
