WRV200 DDNS-Update fails at PPTP Connection
Feb 25th, 2010
Hello!
I'm using the WRV200 Router (1.0.39) with an ADSL-Modem (Thomson) to connect to an Austrian ISP. So i have to use the PPTP-Connection to "dial in".
When i'm using this setting DDNS-Update via dyndns.org fails. The Status always says "diasabled". (The Account-Settings are checked)
A second WRV200 at another location uses a solid WAN-IP. This Router doesn't have any Problems with DDNS.
How can i solve this Problem?
Can you explain me the difference between normal and ETSI-Firmware?
Best regards
Mosquito
josruiz Mon, 03/01/2010 - 14:10
Hello Mr. Mosquito; the best advise that I can give you at this time is to follow this steps then retry to establish your connection,
-- factory default your router
--Down and uplaod the latest firmware into you router
--Manually reconfigure your router-----( DO NOT UPLOAD THE OLD CONFIGURATION)
-- Do a port forwarding with the server's LAN ip address under the port forwading tab in your router
Note:don't forget to create your account in your server before establishing any PPTP connection. If this does not work please contact us at 1866-606-1866 US/Canada.
Related Content
