WRV200 DDNS-Update fails at PPTP Connection
Feb 25th, 2010
I'm using the WRV200 Router (1.0.39) with an ADSL-Modem (Thomson) to connect to an Austrian ISP. So i have to use the PPTP-Connection to "dial in".
When i'm using this setting DDNS-Update via dyndns.org fails. The Status always says "diasabled". (The Account-Settings are checked)
A second WRV200 at another location uses a solid WAN-IP. This Router doesn't have any Problems with DDNS.
How can i solve this Problem?
Can you explain me the difference between normal and ETSI-Firmware?
Best regards
