Renaming Pix 525 Interfaces
Answered Question
Feb 25th, 2010
We are in the process of upgrading our ISP
connection from 100Mb to 300Mb.
We currently utilize ethernet0 with a nameif of "outside"
When we upgrade, we will be utilizing gb-ethernet0 with a nameif of "intf2".
As this upgrade will be a "hot cut", can I simply change the nameif of gb-ethernet0 to "outside" to maintain existing configuration references to "outside".
ethernet0  will be disconnected for the upgrade.
Tom Maguire
Correct Answer by KARUPPUCHAMY MA... about 7 years 5 months ago
//As this upgrade will be a "hot cut", can I simply change the nameif of gb-ethernet0 to "outside" to maintain existing configuration references to "outside".//
this is the best solution for migrating link from 100 Mbps to 300Mbps.
In this scenario no need to change the ACL.NAT and etc.  so no worries...only the thing is need to change then new interface name as "OUTSIDE" and the security-level also sholud be same as the existing one..
advance wishes for your migration..
regards
karuppu
Overall Rating: 5 (2 ratings)
Correct Answer
KARUPPUCHAMY MA... Thu, 02/25/2010 - 07:31
  • Silver, 250 points or more
regards
karuppu
Kureli Sankar Thu, 02/25/2010 - 07:43
  • Cisco Employee,
First you have to issue no nameif on the ether0 which is presently the outside which will remove all lines referring to outside
like ssh lines and http lines and access-g lines.
Once you configure the new gig interface as the outside interface you will have to put back the removed access-g, ssh and http lines. The access-list will not be removed just the access-group line.
-KS
tffmaguire Thu, 02/25/2010 - 07:43
Thanks Karuppu.
That was the answer I was hoping for.
Tom
KARUPPUCHAMY MA... Thu, 02/25/2010 - 07:45
Thanks for your comments..
if you find my comments are ok...please rate it..
regards
karuppu
