Port Channel config. between Foundry FastIron and Cisco 6500
Feb 25th, 2010
  • Bronze, 100 points or more
Dear Experts ,
I'm just trying to configure port-channel between foundry fastiron and Cisco 6500 . The portchannel showing up , but the VLAN traffic seems to be not passing through the trunk ....any clues ?
On Cisco 6500
interface Port-channel1
switchport
switchport mode trunk
switchport trunk allowed vlan all
switchport nonegotiate
interface GigabitEthernet3/16
switchport
channel-group 1 mode active
interface GigabitEthernet3/37
switchport
On Foundry FastIron
interface ethernet 0/1/21
link-aggregate configure key 10000
link-aggregate active
interface ethernet 0/1/22
Regads
Haris
Overall Rating: 3 (1 ratings)
KARUPPUCHAMY MA... Thu, 02/25/2010 - 07:47
  • Silver, 250 points or more
can you paste the outpout of the below command in your cisco switch
sh etherchannel summary
regards
karuppu
Haris P Thu, 02/25/2010 - 07:54
500-test#sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi3/16(P)  Gi3/37(P)
Foundry-fastiron#sh link-aggregate
System ID: 0012.f289.d340
Long  timeout: 90, default: 90
Short timeout: 3, default: 3
Port   [Sys P] [Port P] [ Key ] [Act][Tio][Agg][Syn][Col][Dis][Def][Exp][Ope]
0/1/21      1        1       1   Yes   L   Agg  Syn  Col  Dis  No   No   Ope
0/1/22      1        1       1   Yes   L   Agg  Syn  Col  Dis  No   No   Ope
Foundry-fastiron#sh trunk
Configured trunks:
Trunk ID: 21
Hw Trunk ID: 1
Ports_Configured: 2
Primary Port Monitored: Jointly
Ports         0/1/21  0/1/22
Port Names    none    none
Port_Status   enable  enable
Monitor       off     off
Rx Mirr Port  N/A     N/A
Tx Mirr Port  N/A     N/A
Monitor Dir   N/A     N/A
Operational trunks:
Trunk ID: 21
Hw Trunk ID: 1
Duplex: Full
Speed: 1G
Tag: No
Priority: level0
Active Ports: 2
Ports         0/1/21  0/1/22
Link_Status   active  active
LACP_Status   ready   ready
6500-test#sh interfaces trunk
Port          Mode         Encapsulation  Status        Native vlan
Po1           on           802.1q         trunking      1
Port          Vlans allowed on trunk
Po1           10-500
Port          Vlans allowed and active in management domain
Po1           10,100-101
Port          Vlans in spanning tree forwarding state and not pruned
Po1           10,100-101
Haris
KARUPPUCHAMY MA... Thu, 02/25/2010 - 08:04
The port-channel and the trunk configuration is ok in both end switches.
As far as my concern that , there might be issue with VLAN configuration.
Check VLAN,VTP and spanning tree configuration in Fastlron Switch
regards
karuppu
jfraasch Thu, 02/25/2010 - 10:17
What VLAN are you trying to get through?
The Cisco shows a range of VLANs being allowed but certainly not all of them.
James
Haris P Thu, 02/25/2010 - 14:05
I'm trying to pass all VLANS through the link .Is it not possible ?
Jon Marshall Thu, 02/25/2010 - 14:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes it is possible but at the moment your trunk is forwarding vlans 10, 100 & 101. Is this one of the vlans you are trying to use ?
Jon
Haris P Thu, 02/25/2010 - 22:25
Dear Marshal,
Thanks for the reply , but I only configured  vlans 10, 100 & 101 on my 6500 switch . That's why it's showing that this are the only VLANs allowed and active in management domain ....I also tried changing the system priority to low(higher value) in foundry side ..but nothing helped me
The following is my 6500 vlan config
vlan 10,100-101
interface Vlan10
ip address 172.16.27.17 255.255.255.248
interface Vlan100
ip address 172.16.27.1 255.255.255.248
ip route-cache flow
interface Vlan101
ip address 172.16.27.9 255.255.255.248
ip route-cache flow
Haris
Haris P Thu, 03/04/2010 - 13:03
Dears ,
The problem has been fixed .The Issue was on Foundry side. On Foundry trunk port I need to tagg with All VLANS to pass the traffic
vlan 2 by port
tagged ethe 0/1/23 to 0/1/24
vlan 10 by port
vlan 100 by port
vlan 101 by port
haris
