High ping loss with small payload
Feb 25th, 2010
Hello, I have an interesting issue effecting one of my nodes. I am able to successfully ping using a 1500 byte frame but get high packet loss when using a standard 100 byte frame?  Anyone seen this? I am going to have a tech go and connect to another port to see if its an issue on the port. Here is an example:
  • #ping 172.xxx.xxx.xxx repeat 100
Sending 100, 100-byte ICMP Echos to 172.xxx.xxx.xxx,  timeout is 2 seconds:
Success rate is 95 percent (95/100), round-trip min/avg/max = 4/8/24 ms
  • #ping 172.xxx.xxx.xxx repeat 100 size 1500
Sending 100, 1500-byte ICMP Echos to 172.xxx.xxx.xxx, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 12/17/28 ms
Giuseppe Larosa Thu, 03/04/2010 - 05:48
Hello Brent,
did the port change provide you a solution to this issue?
Hope to help
Giuseppe
brentalee Mon, 03/08/2010 - 07:34
Morning Giuseppe, sorry to reply so late, no the port change did not fix the issue. We are still seeing this present on many of our Nodes.
Brent
