CallManager 4.1.3 to 7 (Intercluster)
Answered Question
Feb 25th, 2010
Hi all
Can anyone tell me if you can create intercluster trunk between CM 4.1.3 and 7.0
Thanks in advance
Correct Answer by Jaime Valencia about 7 years 2 days ago
Yes, configure an ICT non-GK controlled between them and you're good to go
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
