I cant revert back to PVST from MST on 4948
nawas Thu, 02/25/2010 - 12:15
What vtp mode this switch is in? try changing to transparent and then change the STP mode.
Jon Marshall Thu, 02/25/2010 - 12:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
We have installed a 4948 its spanning tree mode is MST, we need it to be in PVST.
spanning-tree mode ? - only has the option for mst
no spanning-tree mode - doesnt revert the switch to PVST mode.
How do i get the switch into PVST mode?
Chris
Chris
What image are you running because the LAN Base image does not support PVST+ or RPVST+ which is probably why you are not seeing these options with the "spanning-tree mode .." command.
Jon
Jon Marshall Thu, 02/25/2010 - 14:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
Jon,
Thank you, i had considered the possibilty that it wasnt in the IOS but quickly dismissed it as a crazy idea, thank you again.
We have (cat4500-LANBASEK9-M), Version 12.2(52)SG
I will now attempt to find some documentation as to why this is the case
Chris
Surprised me as well as the LAN Base image is meant to be the L2 image only. Weirdly if you look at the configuration docs for the 4948 switch up to 12.2(50) it clearly states that LAN Base image does not support PVST+ or RPVST+.
But the 12.2(52) configuration guide doesn't make the same statement. Might be worth having a look at the release notes.
Jon
