02-25-2010 12:26 PM
I have an ASA 5510 at Site A with a L2L tunnel to another site, Site B. Single subnet at each site. In a few weeks we will be adding a second
Internet connection to Site B, so both connections will be active. But we want traffic to go over the new connection unless it goes down, then use the other. How do I set that up on the ASA so it doesn't get confused as to which tunnel to take to get to the Site B subnet? Can this be done?
Solved! Go to Solution.
02-25-2010 01:36 PM
If ASA on Site B is going to have two different interfaces terminating the VPN, then on Site A you define two peers (one preferred).
i.e.
cry map mymap 10 set peer 1.1.1.1 2.2.2.2
Assuming that 1.1.1.1 is the ASA's Site B first public IP and 2.2.2.2 is the ASA's Site B second public IP.
The ASA at Site A will attempt to establish the tunnel to 1.1.1.1 first and if it fails, it will try 2.2.2.2
On Site B, the ASA should have the crypto map on both interfaces.
You can set the Site B ASA to originate the tunnel and the ASA on Site A to receive.
Federico.
02-25-2010 01:20 PM
Yes you can do that with routing.
You set up a preferred route for the preffered ISP and then a second route in case the primary ISP fails.
If the ASA at Site B has only a single outside interface terminating the tunnel, that's all you need to do.
If the ASA is going to terminate both ISP connections on different interfaces, then you need to apply the crypto map to both interfaces on ASA Side B and have the ASA on Side A pointing to the primary IP as the first option in the crypto map and secondary option for the other ISP.
Federico.
02-25-2010 01:28 PM
Hi Federico,
Thanks for the reply! So on site A crypto map I can specify the primary address to use to get to Site B and if that's not reachable it will try a secondary address? What is the crypto map command to do that?
Thanks!!
02-25-2010 01:36 PM
i.e.
Federico.
02-25-2010 01:41 PM
Perfect, thanks!!
03-02-2011 01:40 PM
Glad I could help.
Thank you Diane :-)
Federico.
