MeetMe with external callers
Answered Question
Feb 25th, 2010
Is it possible for external callers to join a meetme conference without DID numbers on CME?   Our internal meetme works just fine.
Correct Answer by david-lima about 7 years 3 months ago
Hi, do you added the meetme number in the CUE (I think you are using this solution), in the user->add user option page?. For example: username:meetme, number: 2222, etc.
hth
David
Overall Rating: 5 (1 ratings)
david-lima Thu, 02/25/2010 - 13:12
  • Bronze, 100 points or more
Hi, here you have a comment, if an internal user initiate the meetme, the external user only dial the meetme number if there is an AA or could be transferred to the meetme number by the recepcionist.
hth
David
shannon3571 Thu, 02/25/2010 - 13:18
Unfortunatley the external caller can't dial the meetme number since there are no DID's (there is no receptionist either) However, when the AA picks up I was hoping to have the external caller dial the meetme extension at that time.  The AA bombs out and says it is an invalid number.  Any other ideas?
Correct Answer
david-lima Thu, 02/25/2010 - 13:25
hth
David
shannon3571 Thu, 02/25/2010 - 13:36
That worked!  I completely overlooked that.  Thanks!
