Warning message
Current Wait Time - HTML WallBoard
Answered Question
Feb 24th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I am in the process of making a Wall Board for a new call center we’re putting in. One of the metrics I’d like to be able to show to the group would be the current wait time on the various queues.
I have created a script that goes out reads a simple HTML file. Pulls out CSQ Reporting statistics stores them in various variables. Then does a keyword trans form with the results from the variable back into the HTML document. Very simple and working fine for all metrics except current wait time, this always shows as -1. Ideally it would output in hh:mm:ss format. I’m not sure how to take an integer and output back into the desired format.
Thanks in advance.
UCCX 7.0(1)SR05_Build504
Correct Answer by Anthony Holloway about 7 years 5 months ago
Without going into a lot of detail, a -1 means the system cannot determine a metric at that instance.  So you can either treat it as a wati time of 0 or Invalid.
Your challenge seems to be, how to convert seconds into MM:SS.
Script:
wait_time = get reporting stats()
set wait_time = (wait_time < 1) ? 0 : wait_time
set conv_wait_time = "" + (wait_time / 60) + ":" +  (wait_time % 60)
Or if you want to pad single digits, change the last set to this:
set conv_wait_time = {
     int minutes = wait_time / 60;
     int seconds = wait_time % 60;
     return ((minutes < 10) ? "0" : "") + minutes + ":" + ((seconds < 10) ? "0" : "") + seconds;
Overall Rating: 5 (1 ratings)
Correct Answer
Anthony Holloway Thu, 02/25/2010 - 09:36
  • Purple, 4500 points or more
Script:
tpfrankli Thu, 02/25/2010 - 17:10
Thanks for the information, now what may seem like a dumb question. Where does this script get placed at? Is this a custom script in the UCCX wallboard script or does this go into my HTML file?
If I'm following the top half of your post you've definded two variable:
conv_wait_time
and wait_time
Are these int variables? My guess would be that wait_time is as you're storing the reporting statistics into it.
tpfrankli Fri, 02/26/2010 - 07:22
I've spent some more time looking at this and I follow what you posted. It all goes into the script and I do define two new variables.
Anthony Holloway Fri, 02/26/2010 - 15:24
That is correct.  Glad you were able to work it out on your own.  If this solved your question, would you mind updating the post to reflect that?
Related Content
