Cisco P/N for CISCO877W router's AC Power Adapter
Feb 25th, 2010
There are some links in Cisco regarding this:
Some links says the P/N for all Cisco 8xx series routers is PWR-800-WW1.
Some other links say the P/N for 85x and 87x series routers is PWR-850-870-WW1=
I have spent several hours trying to find out which is right.
What is the right P/N for the AC power adapter for
  • Please point me to the a URL at Cisco site
I tried a PWR-800-WW1= and it wouldn't fit into a
CISCO877W-G-A-K9. The connector plug is bigger than the one in the router.
Overall Rating: 4 (5 ratings)
Sergei Vasilenko Sun, 02/28/2010 - 23:59
The PWR-800-WW1= is for Cisco 800 sries (801-804  namely) - you could check:
For 87x you would need:
PWR-850-870-WW1= Cisco 850/870 series external AC power supply spare
It is just a brick and when ordered it
requires the country specific cord (if you don't have one yet).
For example, the CAB-AC2= for the 87x routers (AC Power cord North America).
astanislaus Mon, 03/01/2010 - 15:39
Thank you very much.
Just as the link you pointed out for PWR-800-WW1= is there a link on CCO pointing to PWR-850-870-WW1=
Paolo Bevilacqua Mon, 03/01/2010 - 15:56
You are being told by a Cisco employees, from the Cisco official price list:
Part number: PWR-850-870-WW1=
Description: Cisco 850/870 series external AC power supply spare
You do not need any other link for this information.
Better would be to rate Sergey's post for what is really worth: 5 stars and Solved mark. I certainly did.
Sergei Vasilenko Tue, 03/02/2010 - 00:41
Indeed, the GPL Description is quite self-descr. Didn't saw the pn described explicitly on cco.
Most likely, cause when you order the cisco87x (or some others 800 series) it is already comes with power supply.
You just need to choose proper power cord (you migh confirm this w cco dynamic configuration tool).
So normally you do not need to order it separatly, might be only when its fails and you need a RMA.
Also you could just google for "PWR-850-870-WW1=" and you would get a lot of 3-rd parties links
with some more details. One example for Cisco 800 Series could be:
