2611xm Terminal Server + ACS + reauthentication when selecting menu options
Answered Question
Feb 25th, 2010
I've managed to setup ACS Authentication on my  2611xm router,
after you login to the router I have a autocommand setup to run a menu.
My problem is  when you select the option on the menu,
You are then re prompted to reauthenicated against  the router again before connecting to the line,
can any one tell me how  to stop this from happening.
Thanks for your time and effort in advance, I  have enclosed a config below.
DDRAS01#sh running-config
Building  configuration...
Current configuration : 6854 bytes
! Last  configuration change at 10:28:49 AEST Sun Feb 21 2010 by <removed>
!  NVRAM config last updated at 19:25:53 AEST Sat Feb 20 2010 by  <removed>
version 12.4
service timestamps  debug datetime msec
service  password-encryption
service linenumber
service  sequence-numbers
hostname DDRAS01
boot-start-marker
boot-end-marker
security  authentication failure rate 3 log
security passwords min-length 6
logging  buffered 51200 informational
logging rate-limit all 10000
logging  console critical
enable password 7 <removed>
aaa  new-model
aaa authentication login default group  tacacs+ local
aaa authentication login if_needed local
aaa  authentication enable default enable
aaa authentication ppp  default local
aaa authorization exec default group tacacs+ local  if-authenticated
aaa accounting exec default start-stop group  tacacs+
aaa accounting commands 15 default start-stop group  tacacs+
aaa session-id common
clock timezone AEST 10
clock  summer-time AEST recurring last Sun Oct 2:00 last Sun Mar 3:00
no  network-clock-participate slot 1
no network-clock-participate wic  0
ip cef
ip domain list  <removed>
ip domain  name <removed>
ip host dd-cr-01e 2033 172.16.1.1
ip  host ddsws01 2034 172.16.1.1
ip host ddsws04 2035 172.16.1.1
ip  host ddce565 2040 172.16.1.1
ip name-server <removed>
username  netops privilege 15 password 7 <removed>
ip  ssh source-interface FastEthernet0/0
ip ssh logging events
ip  ssh version 2
interface Loopback0
ip  address 172.16.1.1 255.255.255.255
ip address <removed> 255.255.255.0
speed 100
full-duplex
interface Serial0/0
no  ip address
shutdown
interface BRI0/0
no ip  address
encapsulation hdlc
shutdown
interface  FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0  0.0.0.0 <removed>
ip http server
no ip http  secure-server
ip tacacs source-interface FastEthernet0/0
ip  radius source-interface FastEthernet0/0
logging facility local6
logging  <removed>
snmp-server community <removed> RO
snmp-server  community <removed> RW
snmp-server location <removed>
snmp-server  contact NetOps
menu ddras01 title ^C
Cisco  Terminal Server
Select the number from the list below
Use  'ctrl+shift+6' then 'x' to switch back to the menu
^C
menu  ddras01 text 1 Connect to DD-CR-01
menu ddras01 command 1 resume  dd-cr-01 /connect telnet dd-cr-01 2033
menu ddras01 text 2 Connect  to DDSWS01
menu ddras01 command 2 resume ddsws01 /connect telnet  ddsws01 2034
menu ddras01 text 3 Connect to DDSWS04
menu  ddras01 command 3 resume ddsws04 /connect telnet ddsws04 2035
menu  ddras01 text 8 Connect to DDCE565
menu ddras01 command 8 resume  ddce565 /connect telnet ddce565 2040
menu ddras01 text 9 Exit
menu  ddras01 command 9 menu-exit
menu ddras01 clear-screen
menu  ddras01 status-line
menu ddras01 line-mode
tacacs-server  host 10.2.0.50
tacacs-server directed-request
tacacs-server  key 7 <removed>
control-plane
privilege  exec level 15 write terminal
privilege  exec level 1 ping
privilege exec level 10 undebug ip icmp
privilege exec level 10 undebug all
privilege exec level 10 terminal monitor
privilege exec level 15 show  running-config
privilege exec level 5 show configuration
privilege exec level 10 debug ip icmp
privilege exec level 10 debug all
privilege exec level 10 clear interface
privilege  exec level 10 clear counters
line  con 0
logging synchronous
line  33 64
no exec-banner
exec-timeout 0 0
no  activation-character
no exec
transport preferred telnet
transport input all
escape-character 27
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
logging synchronous
autocommand  menu ddras01
line vty 5 181
logging synchronous
ntp clock-period 17208487
ntp source  FastEthernet0/0
ntp server <removed>
end
Correct Answer by jedubois about 6 years 10 months ago
It looks like you have the autocommand under vty 0 4 as well.
Do you know what line you are accessing when you are prompted for authentication.
--Jesse
     You have aaa login default set up for authentication, with this on you will get prompted
     when attempting to access the any line.
     Under line VTY 5 181 try adding:
     login authentication NOAUTH
     authorization exec NOAUTH
     add the aaa lines:
     aaa authentication login NOAUTH none
     aaa authorization exec NOAUTH none
     That should stop the authentication to the lines.
--Jesse
Overall Rating: 5 (2 ratings)
Correct Answer
jedubois Fri, 02/26/2010 - 13:53
     add the aaa lines:
--Jesse
ddolbel Fri, 02/26/2010 - 14:11
Hi Jesse
I have made the changes you recommended however i'm still getting prompted to reauthenticate each time I choose a menu entry,
I have included a updated copy of the config, any help you can provide if greatly appreaciated.
DDRAS01(config)#do sh runnin
Current configuration : 7371 bytes
! Last configuration change at 17:55:22 AEST Sun Feb 21 2010 by david
! NVRAM config last updated at 11:07:30 AEST Sun Feb 21 2010 by david
version 12.4
service linenumber
hostname DDRAS01
boot-start-marker
boot-end-marker
enable password 7
aaa new-model
ip cef
ip domain list
ip domain list
ip domain name
ip host dd-cr-01 2033 172.16.1.1
ip name-server
ip name-server
ip ssh version 2
interface Loopback0
ip address 255.255.255.0
speed 100
full-duplex
interface Serial0/0
no ip address
shutdown
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
ip http server
logging
snmp-server community RO
snmp-server community RW
snmp-server contact
^C
menu ddras01 text a Clear connection to DD-CR-01
menu ddras01 command a clear line 33
menu ddras01 text b Clear connection to DDSWS01
menu ddras01 command b clear line 34
menu ddras01 text c Clear connection to DDSWS04
menu ddras01 command c clear line 35
menu ddras01 text h Clear connection to DDCE565
menu ddras01 command h clear line 40
menu ddras01 text x Exit Menu
menu ddras01 command x menu-exit
menu ddras01 text l Logout
menu ddras01 command l logout
tacacs-server host
tacacs-server key 7
control-plane
line con 0
password 7
logging synchronous
line 33 64
no exec-banner
exec-timeout 0 0
no exec
transport input all
escape-character 27
stopbits 1
line aux 0
line vty 0 4
password 7
logging synchronous
line vty 5 181
password 7
logging synchronous
ntp clock-period 17208478
ntp server
end
Correct Answer
jedubois Fri, 02/26/2010 - 14:18
--Jesse
ddolbel Fri, 02/26/2010 - 14:56
ok I opened 2 sessions to the router
from the 2nd session I choose a menu option
now on the 1st session I ran sh users command
output below
DDRAS01#sh users
    Line       User       Host(s)              Idle       Location
  33 tty 33               incoming             00:00:19 dd-cr-01
  66 vty 0     david      dd-cr-01       00:00:19 netops54.workstations.
* 67 vty 1     david      idle                 00:00:00 netops54.workstations.
  Interface    User               Mode         Idle     Peer Address
I hope this helps.
ddolbel Fri, 02/26/2010 - 16:19
Never mind Jesse
I solved it
adding
and I need to add the
authentization exe NOAUTH
to line 33 64
line 33 64
no exec-banner
exec-timeout 0 0
no exec
transport input all
escape-character 27
stopbits 1
line vty 0 4
password 7
logging synchronous
line vty 5 181
password 7
logging synchronous
jedubois Tue, 03/02/2010 - 06:32
Yes my apologies I listed the wrong lines in my post.
--Jesse
