Remote Desktop Connection Via 2 ASA FW
Feb 25th, 2010
Hi Gentlemen,
                   Could any one help to advise the remote desktop connection between the 2 ASA 5510 FW IP Sec Tunnel connection?
I have already setup the the 2 remote sites via the 2 ASA FW IPSec Tunnnel and would like to remote desktop to Site A from the Site B. But one of the problem PC ( Windows XP Professional ) is still having problem to remotely connect.When I remote desktop to that PC, the remote desktop window pop up but the login screen didn't show up and finally it time out . I' m able to ping that PC and remote desktop connnection port is als opened as well.
From the command prompt
c:\ telnet 192.168.1.x 3389
( The port is opened ) .
The Current Config is as per attach file.
yamramos.tueme Wed, 03/10/2010 - 10:50
Hi Nay!
Perhaps you can try adjusting the mss.  You can do this with the following command:
sysopt connection tcpmss 1300
Default is 1380...
You can give that a try.
Cheers!
