To identify the object groups that are not being used in ACLs
Hi, I have a 200 pages of configuration of ASA , and i have to map the existing configuration to the new setup. There are around 100 pages of network objects that were created during last 2-3 years. Not all of these network objects are being used in the ACLs. I don't want to use these network objects in my new configuration, but how can i identify (smartly ) that which specific network objects should i skip?
Panos Kampanakis Fri, 02/26/2010 - 12:27
you can do "sh run | i " to check the ACLs it is used.
Also you can use ASDM that has a "where used" option in the object groups.
I hope it helps.
ssocsupport Mon, 03/01/2010 - 00:59
It require manual validation using CLI
- issues the command sh run object-group network or sh run object-group service to knw the list of object group configured
- issue the command "sh run | i " to kwn the object group used in ACL
- if you have no ACL listed, while using the above command; then there is no ACL configured
However, this is not the smartest way..!!
ssoc support
