reg: fxs config
Feb 25th, 2010
Dear sir,
Iam trying for small lab setup i have cisco 2800 series router in that i have 2port FXS
cord is there now my set up is
I connected router G0/0 to PBX ethernet port in that pbx i have ip gateway cord now iam
trying to configure the router in such a way that iwant to call from gateway card through
FXS and from FXS to gate way cord.
Both sides i have to send a call and receive a call .In this senario how can i configure
the router FXS ports to send/receive calls.
plz help me in this config
Mansoor Ahmed Sat, 02/27/2010 - 16:19
On the 2800 router, have you setup dial-peers and pointed them to the PBX?
What PBX are you connecting to your 2800 router?
Here is an expamle of a dial-peer.
dial-peer voice 1 pots
description POTS incoming dial-peer
incoming called-number .
dial-peer voice 100 pots
destination-pattern 1000
port 0/3/0
vasuramnet Sun, 02/28/2010 - 21:23
Hi Mansoor Ahmed,
Thanks for ur reply and in ur config there is no session targer weather i have to give session target also
My set up is -----
   analog phone---------------PBX(ip pbx)-----------------router(2800)---fxs(2port)------analog phone
Is there any sample config
