CIPC needed licenses
Feb 26th, 2010
I want to now, which licences are needed (or what to
order) when you use the ip communicator/softphone. I know
that the CIPC use 3 dlu's, but what about the
software itself, and what when you use
a handset like the phone 7941 and a softphone in combination.
Aaron Harrison Fri, 02/26/2010 - 00:53
  • Community Spotlight Award,
    Member's Choice, May 2015
You need to buy the CIPC software for each PC - part is SW-IPCOMM
You then need DLUs - each CIPC will take 3 DLUs.
You can then link up to two softphones to a single desk phone for adjunct licensing - on the config page for the CIPC, you set the 'Primary Phone' to the desk phone you want to associate it with. When you do this, the license usage is reduced to 1 DLU.
Please rate helpful posts...
Aaron
stowellp Fri, 02/26/2010 - 01:45
  • Bronze, 100 points or more
The part SW-IPCOMM doesn't cost anything, and you do not get anything for it. If you have download privilages on CCO just download the software and install it. As you rightly pointed out it takes 3 DLUs, this is how Cisco charge for IPC.
Cheers,
Phil
Aaron Harrison Fri, 02/26/2010 - 02:10
I can 'just download' IOS too - is that free as well?
That part is the top level one, if you check the pricing tool you will see there are single and bundle parts such as SW-IPCOMM-E1  which have non-zero costs.
As far as I am aware you buy CIPC like you would buy a phone, and then you may download it.
To use it with CCM, you also need the DLUs.
The only possible exception I'm aware of to this is if you are under CUWL licensing... that may or may not include the softphone licenses.
stowellp Fri, 02/26/2010 - 02:46
We're not talking about IOS.
I am speaking through experience when trying to order IPC....
We asked for a quote through our gold partner for Video Advantage cameras and IP Communicators just before December last year using the part no. SW-IPCOMM-E1. When we got the quote back there were costs the cameras, but there was a zero cost for the IPCs and we didn't receive the software on CD, the partner told us that we had to download it.
Phil
Rob Huffman Fri, 02/26/2010 - 07:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey guys,
Just thought that I might add a touch here
We have to pay for each and every IP Communicator License on a
per user basis. We could download them at will, but that would be
breaking the "honor based" relationship here.
We just purchased another 10 (about $180US each I think)
Cheers!
Huff
