02-26-2010 04:43 AM - edited 03-06-2019 09:54 AM
i am trying to connect 2950 and 2960
1) Trunk port is up on both the switch
2) i can see other switch when i do sh cdp neigh
3) VTP domain name is blank for both the switch
4) There is no VTP password
but still VLANs are not getting transffered from 2950 to 2960. Any idea .....
regards
Neo
02-26-2010 05:04 AM
Are the needed VLANs configured on both switches?
Can you post your configs?
Can you post the output of "show interface interface-name (fe.Gi0/1) trunk" of both switches?
Can you post "show spanning-tree"?
HTH,
Dario
02-26-2010 05:16 AM
On server switch VLANS are configured
not possible
output is same.Trunking=On , Default Encapsulation DoT1q
Port is fwding mode
regards
Neo
02-26-2010 05:18 AM
What about the output of "show vlan" on both switches?
02-26-2010 05:20 AM
On Old switch its showing 8 VLANs but in new switch only default VLANs are showing.
regards
Neo
02-26-2010 05:28 AM
What is your problem actually?
You have configured VLANs on a switch, now you want another switch to learn these VLANs and allow these VLANs between these 2 switches?
Please describe your problem clearly.
02-26-2010 05:10 AM
Have you tried specifying a VTP domain, you may well need this for VTP to work I have never tested.
Chris
02-26-2010 05:21 AM
I cant specify as client is not permitting .
regards
Neo
02-26-2010 05:29 AM
Specify the VTP domain on the VTP server and as long as no VTP password is set the clients should change automatically.
02-27-2010 03:43 AM
let's suppose swA the old switch and swB the new one
first, make sure swB's VTP configuration does not overwrite swA's config. You can, e.g., put swB in Transparent mode (configuration register is reset to 0), delete vlan.dat, set vtp mode to Client, connect it to swA, configure correct vtp domain name (and password if any).
If you connect swB to swA without these measures, you may end up with VLANs configuration on swA being overwritten by the VLAN configuration on swB.
02-27-2010 01:27 PM
How do you expect the VLANs to propagate from the VTP Server to the VTP client if the following are missing:
1. VTP Domain name; and
2. VTP password.
If you don't have any values in any of them, VTP propagation won't work.
