server hardware for CUCM 6 upwards
Answered Question
Guys,
I plan to buy a server to start with my Voice lab. I have the below spec for the sever and would like to know if CUCM will run on it with the VMware.
I plan to upgrade this servers with 8GB of RAM.
Could you guys please let me know if CUCM will run on both of the below.
1) HP ProLiant ML115 G5 AMD Opteron 1354 Quad Core / 1GB / 160GB / DVD Optical / 1 Year Warranty / Tower Server
2) HP ProLiant ML110 G5 – Server – micro tower – 4U – 1-way – 1 x Xeon 3065 / 2.33 GHz – RAM 1 GB – HDD 1 x 250 GB – DVD±RW (+R double layer) – Gigabit Ethernet -
Correct Answer by Brandon Buffin about 7 years 5 months ago
Yes, CUCM will install on these servers using VMware for use in a lab environment. Neither server will be supported by Cisco for use in a production environment. Virtualization support for a production environment will begin with CUCM 8 and will initially be supported only on UCS.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Fri, 02/26/2010 - 07:04
  • Purple, 4500 points or more
Hope this helps.
Brandon
Hi Brandon,
I now have the new HP Proliant AMD opteron Quad Core server with 1TB HD and 8Gig RAM.
I am trying to install CUCM 6.0.1 on a Virtual machine and get this error "Could not find kernal image:linux" Does this mean my image is corrupted? Where can i source an image for CUCM7.0 or CUCM7.1. Could you please help. I have this server since a week and unable to progress further.
Mohammed
Brandon Buffin Tue, 03/16/2010 - 05:19
Yes, this could be caused by a corrupt image. I have seen this problem mentioned with other CUCM versions. Would recommend obtaining another DVD.
Brandon
Brandon Buffin Wed, 03/17/2010 - 05:59
No, you will not be able to download the full install DVD image. You'll need to obtain another disk.
Brandon
