update WS-C2950G-48-EI
Answered Question
Feb 26th, 2010
Hello
I'd like to update IOS of a  WS-C2950G-48-EI.
Now it runs 12.1(22)EA4a. Doku says to use
archive download-sw
But my switch doesn't know this command.
sw78#archive ?
  tar  List or extract files in a tar image
Any ideas?
thanks in advance
Thomas
Correct Answer by Ganesh Hariharan about 7 years 1 month ago
archive tar /xtract tftp://x.x.x.x/iosname.tar flash:
works fine
you also have to set the new image to boot
conf term
boot system flash:.bin
That Great the command work and thanks for the additional input for changing the image to boot. It will be helpful if you can mark this thread as resolved so that other also get beniffitted.
Ganesh.H
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Fri, 02/26/2010 - 07:52
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello
thanks in advance
Any ideas?
sw78#archive ?
Thomas
Hi Thomas,
Check out the below link for step by step procedure to upgarde IOS for 2900 series switches
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml
Hope to Help !!
Ganesh.H
Correct Answer
Ganesh Hariharan Sun, 03/07/2010 - 23:25
works fine
conf term
Ganesh.H
