Admin Interface on SPA504G
I noticed that there are options on my phone web interface that appear as though I should be able to modify them but I am unable to find a way to get into an "admin" mode for my phone.  Specifically I would like to change my headset input gain, which looks like it is possible through the web interface.
I have tried going to http://phoneip/ and http://phoneip/admin but both are a view-only site.  What would I need to do to get into an admin mode for my phone to adjust these settings?  Do I need to change something on the UC560 or is this a phone setting?
nseto Mon, 03/01/2010 - 16:16
When the 50x phone is connected to the UC, the config changes must be done through the UC.
nseto Mon, 03/01/2010 - 17:13
It should be in the UC config file for the phones but the easiest way is to change the phone to SIP mode temporarily by going into the phone UI.  Under Setup, number 23, you'll see call control setting, change it to SIP and then save and you'll see that you'll be able to make changes through the web UI.  After making your changes, go ahead and change it back to SPCP.
I'm unable to make this setting change on my phone.  I am the admin and could change settings on the UC if I knew what I was looking for.  I found a listing of the files but don't see a file specifically linked to the SPA504G.  Would you be able to tell me specifically which file is the config file for the phone?
Attached is a listing of files on the server.
ibermedia Fri, 07/29/2011 - 10:52
Hi John.
I,m answering because i had the same problem. One year later.
This is the solution (sorry my english):
1) When you use SPA50x phones with UC, the admin interface is out for security.
But you can change any config parameter with a xml file.
2) To see the format of this file you can access your phone web interfaces and type http://ip_phone/admin/spacfg.xml
this file begins with and have a lot of items, one per parameter.
The file ends with
3) You need to write a new file with some of this item, those of your interest. The name of this file is not important.
SPA-cfg.xml for example.
4) Now you must copy this file to the UC flash. You can use the file management utility of CCA.
For example i have supposed you copy it to root directory flash:/
5) Create a TFTP Server entry via CLI, to instruct IOS to serve this file:
tftp-server flash:/SPA-cfg.xml alias /SPA504G-cfg.xml
the alias it's important and depends phone model
you can see the alias you need activating tftp debugging and rebooting the phone you want to configurate.
debug tftp events
in the debugging you can see files looking from the phone when starts. The last file is the alias you must create.
SPA504G-cfg.xml for SPA504G phone model.
This is all. When the file and alias exist on UC, you must reboot the phone. Note: This configuration applies all phones of the same model.
Related Content
