listen others voicemail in my extension
Can I lisen voicemail from other extension in my ip phone?
can somebody help me?
I have Cisco Unity Connection 7.1.3
Jaime Valencia
Yes, dial VM and press * to get the sign in conversation and log in with the right set of credentials.
If you don't know DN and pwd you cannot do this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks that work fine!
