Unity 7 - remote the /ciscopca in the url
Is it cause any problem if we remove the /ciscopca in IIS for the url of unity so people will user the http://unityIP    instead of http://unityIP/ciscopca
William Bell
Yes, I believe that would cause problems.  You could research the possibility of creating another Web Site on the same Unity webserver and have it point directly ciscopca (Home Directory tab).  You would have to modify the web site identification parameters (Web Site tab, Advanced button under "Web site identification", look at "host header value").  But this is just a thought that you would need to test on a lab system first.  My Unity lab system has been offline for a while so I am unable to test this theory at the present moment.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
HTH.
Bill
