Monitoring VPN on ASA
Answered Question
Feb 26th, 2010
Do you guys know if I can monitor the health of the VPN connections terminating on the ASA using SNMP?
I have seen the Cisco Security Manager and other tools, but I need to know if I can really get this information from SNMP, and if so how?
Thank you!
Federico.
Correct Answer by m.sir about 6 years 10 months ago
Yes ASA supports SNMP traps for VPN monitoring
following SNMP traps you can enable on your ASA
asa(config)# snmp-server enable traps ipsec start stop
asa(config)# snmp-server enable traps remote-access session threshold-exceeded
Also I found following discussion here on the forum
https://supportforums.cisco.com/message/1330760;jsessionid=6EB4A6F00AE24CC4067DB6F475C4B002.node0
M.
Hope that helps rate if it does
Overall Rating: 5 (1 ratings)
Correct Answer
m.sir Tue, 03/23/2010 - 05:54
M.
