Setting privileges in Cisco Secure ACS Version 5.1.0.44
Feb 26th, 2010
I am setting privileges in Cisco Secure ACS Version 5.1.0.44.
In the command sets from the ACS server, I denied few commands as can be seen in the attached screenshot and selected 'Permit any command that is not in the table below'.
I am unable to see some commands like "Show running-configuration" from the router I was testing. What changes should I do to see all the commands other than the denied commands. Your help will be rated. Thank you.
Erick Delgado Tue, 03/02/2010 - 15:50
  • Bronze, 100 points or more
The ACS is able to handle permit or deny commands.
I created a configuration example that will help you to understand command shell.(see attach doc)
Instead of using show running-config please use show config.
also make sure that all the users are using privilege 15.
