What is wrong with this basic prefix-list?
Answered Question
Feb 26th, 2010
I have a simple configuration:
R1----R3(bgp 100)------------------------------(bgp 200)R4
Then on R4 I would like to see networks 10.177.206.0 and any 10.2.0.0 network advertised.
However, once I applied the prefix-list shown below, I get no such networks.
Routing is working accordingly because if I remove the prefix-list on the redistribute command on R3, I see all networks advertised OK.
R3#show run
Building configuration...
Current configuration : 1462 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface Loopback0
ip address 10.2.255.15 255.255.255.255
ip ospf 1 area 0
interface FastEthernet0/0
ip address 10.2.80.1 255.255.255.0
ip ospf 1 area 0
speed 100
full-duplex
interface FastEthernet0/1
ip address 10.2.60.105 255.255.255.252
ip ospf 1 area 0
speed 100
full-duplex
interface FastEthernet1/0
ip address 10.2.47.200 255.255.255.240
speed 100
full-duplex
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 10.2.255.15
log-adjacency-changes
redistribute bgp 100 metric 10 subnets
default-information originate
router bgp 100
no synchronization
bgp log-neighbor-changes
redistribute ospf 1 route-map RM_ENG
neighbor 10.2.47.193 remote-as 200
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip prefix-list LIST_ENG seq 5 permit 10.2.0.0/16
ip prefix-list LIST_ENG seq 10 permit 10.177.206.0/24
route-map RM_ENG permit 10
match ip address prefix-list LIST_ENG
set local-preference 200
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R3#
Below is the show ip bgp on R4 if use only "redistribute ospf 1" under the R3 BGP process, without applying the prefix-list.
R4#show ip bgp
BGP table version is 17, local router ID is 4.4.4.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 4.4.4.4/32       0.0.0.0                  0         32768 i
*> 10.2.40.0/24     10.2.47.200              2             0 100 ?
*> 10.2.60.104/30   10.2.47.200              0             0 100 ?
*> 10.2.80.0/24     10.2.47.200              0             0 100 ?
*> 10.2.255.15/32   10.2.47.200              0             0 100 ?
*> 10.177.206.1/32  10.2.47.200              2             0 100 ?
R4#
===BELOW IS THE OUTPUT AFTER I APPLY THE PREFIX-LIST as "redistribute ospf 1 . MY INTENTION IS TO SEE 10.2.40.0/24, 10.177.206.0  and other 10.2.0.0 listed but I only see 4.4.4.4
R4#show ip bgp
BGP table version is 22, local router ID is 4.4.4.4
Correct Answer by Giuseppe Larosa about 6 years 11 months ago
Hello Marlon,
with this formulation
your prefix-list matches only the described prefixes. (exact match)
to get what you want you need to use:
ip prefix-list LIST_ENG seq 5 permit 10.2.0.0/16 le 32
ip prefix-list  LIST_ENG seq 10 permit 10.177.206.0/24 le 32
that is the first prefix/len identifies the block, prefix-list allows then to specify a range of prefix lengths for subnets falling within the block
so if you use:
ip prefix-list LIST_ENG seq 5 permit 10.2.0.0/16 ge 25 le 32
ip prefix-list  LIST_ENG seq 10 permit 10.177.206.0/24 le 30
you will see the full potential of prefix-list with this third formulation some ip subnets will be filtered
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 02/26/2010 - 16:48
Hello Marlon,
so if you use:
Hope to help
Giuseppe
news2010a Fri, 02/26/2010 - 16:55
Indeed. That worked.
Do you know why the subnet in red below appears as /32?
In reality that is a loopback on R12 that I advertised as /24.  Just curious.
Thank you very much.
Do you know why
   Network          Next Hop
Jon Marshall Fri, 02/26/2010 - 21:07
Do you know why
   Network          Next Hop
Marlon
Not entirely sure without seeing configs but if this route is being redistributed from OSPF then OSPF always advertises loopbacks as /32. If you want OSPF to treat it as a /24 then under the loopback interface you need
int loopback 10
ip address x.x.x.x
ip ospf network point-to-point
Jon
Reza Sharifi Fri, 02/26/2010 - 16:49
Can you remove "set local-preference 200" from the route map and test again?
Reza
