How to manage a SA 540
Feb 26th, 2010
Hi All's,
Do you konw where I can find the SA 540 MIB in order to remote manage the device (bandwith, load, memory) ...
I'm using Nagios and need OIDs to pool.
Steven DiStefano Tue, 03/02/2010 - 07:25
I am asking the product team internally and will report back with what they provide.
Steve DiStefano
SE
U.S. Partner Sales
Stephane.Guedon Thu, 05/27/2010 - 04:01
Final answer ...
At this time, the SA 540 is not manageable .... nos oid for memory/CPU ...
Only interfaces ...
Steven DiStefano Thu, 05/27/2010 - 08:27
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
Just clarify the requirement in terms of FCAPS beyond just configuration to fault management, which is what I think you need?
So you have a NMS (Cisco Information Center (Micromuse), or HP Open view), where Traps and maybe SYSLOGs are collected and displayed to alert network managers about the health of their network.  And perhaps you also want to do Performance management tools in the NOC that periodically query the SNMP OIDs for periodic status of CPU and Memory.
So your interested in CPU  utilization passing thresholds and free memory running low.  If not please elaborate on use case?
Stephane.Guedon Thu, 05/27/2010 - 12:16
Hi Steve,
Use cases are:
  1. Fault management (traps send by device to one or more SNMP manager)
  2. SNMP Get values (for capacity and monitoring).
In my opinion here is what's missing on the SA 5xx:
  1. Fault Management => SNMP Version (1,2,3)
  2. Monitoring:
    1. SNMP Version
    2. Get value for all informations such as
      1. All I can get with Device Status( Ressources utilization, Statistics)
      2. VPNs stats
Stéphane Guédon
Steven DiStefano Thu, 05/27/2010 - 13:05
Thanks for taking the time to provide field feedback.   I have passed this to the product Development and Engineering team.
gherbstman Thu, 12/16/2010 - 05:08
I would also suggest Netflow and a way in the built-in interface to view traffic and utilization on a per protocol and per host basis.
