CSA Agent for server
Feb 26th, 2010
i have an CSA agent im trying to install on Server with windowns 2003 Enterperise 64 bit
i know the Agent installation should be done on the background but nothing seems to be installing after i check the process running on windows CSAsetup.exe32 appears when i click install and disappears in 3 seconds back.
jan.nielsen Sun, 02/28/2010 - 15:52
As far as i remember no 64-bit windows o/s'es are supported yet, they will be in 6.0.2 which is coming very soon, but i doubt it will include win2003 64-bit. If you wanna see if it something in the installation that fails, you could create a new agent kit, like the one you use now, but without the silent install flag set.
