published SIP server behind natting
Feb 27th, 2010
I'm trying to publish a SIP server to the Internet, when SIP clients register in SIP server from the public network they get one way audio scenario, they hear audio originating from inside network but their audio won't reach inside network, we are using a 2811 router equiped with advanced security IOS for Internet connectivity (ADSL2+), the SIP server is natted through the 2811 router to the Internet, I read alot about SIP nat traversal and how that the SIP protocol is not nat friendly, yet I cannot figure out how exactly I can resolve the issue, any help would be appreciated
Thank you
ramy.aboamra Sat, 02/27/2010 - 04:37
my client have that too and it works, however they need the sip server published without vpn as well to use all differnet sip capable devices they have
ramy.aboamra Sat, 02/27/2010 - 04:35
well it won't let audio come from outside sip client if the ios natting configurations for sip server have something special i would appreciate the help
ramy.aboamra Sun, 02/28/2010 - 23:12
the thing got sorted out, no problems found with ios natting!!! it was a firewall on the sip server blocking the whole thing, ios natting works like a charm, thanks everyone for your posts
regards
krishan.saran Sun, 11/28/2010 - 18:33
Hi I am also trying this thing from couple of weeks but in may case some time its works some time doesn't, I have system like that
I have SIP server behind the Cisco router and i am using NAT for UDP port number 5060 to SIP server, and i am using a SIP soft phone in my LAPTOP, if i am try to connect it through VPN its works, but if my LAPTOP is behind the NAT at home i have ADSL and wireless router my phone get registered i can make a call if i call my cell phone from my SIP phone it rings but there is no Audio, it i am connecting my LAPTOP directly to ADSL Modem means no NAT than its works fine, i already disabled firewall on my home router and i already tried NAT to my Laptop IP for port number 5060 but didn't work.So i thing i need to do some thing in my home router, and i have a Simple D-LINK wireless router at home.we want to make it working so than i don't need to do any thing at client side it this case my home, definitely we need to open SIP traffic in firewall, I also tried Wireshark, to capture the port numbers it use the different ports for every call, i understand that there might be a range of ports that i need to use for NAT. Any help we will really appreciated
SIP Server=============Cisco Router==============Internet ==============D-Link Router=========Laptop
10.10.11.206                       10.10.11.1        192.168.1.1                              192.168.1.100
  IP NAT inside source static udp 10.10.11.206 5060 int fas 0/4 5060
there is no firewall on cisco router
