Authentication Users on Call Manager without the plugin on the AD.
Feb 27th, 2010
Folks, anyone know how I can authenticate a user at IP phone (Call Manager) on the AD ,like 802.1x, without installing the Cisco plugin on it?
I want something like Radius (IAS) integrated with AD.
David Hailey Sat, 02/27/2010 - 11:06
  • Purple, 4500 points or more
So, you may need to clarify your question but I get the impression you aren't talking about user authentication via AD to web-based components such as CCMUser web page.  It sounds like you want to use AD (or some other solution) at the phone itself to authenticate for applications like say "EM".  In that case, the authentication leverages ther user's PIN that is stored separately in the CUCM DB.  AD is not used in this case.
Is that what you're looking for?  Honestly, I don't know what "plug-in" you're talking about on the AD side.
Hailey
