I have a problem with my Full zoneset database after performing a merge failure recovery, I was trying to import the Active Zoneset from OPP-SAN-Core1# sh zone status vsan 2 to BC19SANSw-A# sh zone status vsan 2 after a merge failure, I think I might have done it incorrectly as I now can't see an Active Zoneset using the edit zone database too. (screenshot attached)
I suspect there is a way to copy back the active zoning database to the full zoning database but I am not sure and don't want to risk loosing connection to my hosts. I have not saved any configuration changes since this action.
Have I wpied my switch configuration? If I reboot the switch will I loose the Active zoning? How can
VSAN: 2 default-zone: deny distribute: full Interop: default
mode: enhanced merge-control: allow
session: none
hard-zoning: enabled broadcast: enabled
Default zone:
qos: none broadcast: disabled ronly: disabled
Full Zoning Database :
DB size: 44 bytes
Zonesets:0 Zones:0 Aliases: 0 Attribute-groups: 1
Active Zoning Database :
DB size: 7440 bytes
Name: Zoneset_Active1 Zonesets:1 Zones:103
Status: Import completed at 21:33:21 UTC Feb 27 2010
session: none
hard-zoning: enabled broadcast: unsupported
Default zone:
qos: none broadcast: unsupported ronly: disabled
DB size: 44 bytes
DB size: 7440 bytes
Status: Activation completed at 14:24:11 UTC Feb 27 2010
