2106 Controller - Why only two PoE ports?
I am trying to build a solution for an SMB with mutliple access points for an indoor and outdoor solution (with Antennas), and looking for a cost effective controller. Looking at the 2106 I was wondering why only two PoE ports? Wouldn't it make sense to make them all PoE so you can power all AP's?
Thanks in advance,
Bob James
PS Let me also ask, how do you support 802.11n with only a 100Mbps Ethernet port?
Overall Rating: 5 (1 ratings)
Christian Isla Fri, 01/14/2011 - 08:06
Then you would be installing all 6-7 AP's in about a 250ft radius.
Leo Laohoo Fri, 01/14/2011 - 21:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You don't.   2100 wasn't meant to support Gig interface of the AP.  It was meant to be for testing and toying around.  It was also meant to support 1130/1240 and older.
Because it was plainly meant for testing purposes only.
Leo Laohoo Sat, 01/15/2011 - 20:01
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings.
Not sure if you are trying to be funny, or that was a serious answer.
Most competitors have all PoE ports, and I'm not saying I want to use them all, just thought it makes sense. As well, with the introduction of the new C series switches that can be run over PoE, just seems logical.
And as for the question or 100M interfaces, even if you want to run 1 AP off the WLC, 100M for the newer AP's is a bottleneck.
Bob James
Leo Laohoo Sun, 01/16/2011 - 13:21
  • Hall of Fame,
    2017 LAN, Wireless
I'm trying not to be funny.  I was also trying to be serious but not that serious as to be mis-interpreted as being condescending or disrespectful.
No arguments there.
True.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
