EIGRP question
Feb 27th, 2010
I have a remote site (network 10.80.180.0) which is accessing two data centers through MPLS. Two data centers are running the same EIGRP on their network and both update carrier BGP with eigrp routes. Both data centers are connected with L2 (dark fiber) and with L3 MPLS. In data center AAA network is 10.80.100.0 and in data center BBB 10.80.150.0. Routers from both datacenters update carrier BGP with the same routes. It is causing some routing issues.
For example:
When PC from remote site on network 10.80.180.0 wants to access Mail Server (10.80.100.100) in data center AAA it goes directly to data center AAA. Then mail server replys to this PC by sending packets to default gateway 10.80.100.1. This router however learns route to 10.80.180.0 from router in datacenter BBB so it sends packets to router in datacenter BBB and he sends packets to 10.80.180.0 network. It creates asymetric routing. Packet leave network 10.80.180.0 and goes to network 10.80.100.0 and returns back from network 10.80.150.0.
Carriers wants me to tag eigrp routes leaving network 10.80.100.0 with different tag than routes leaving 10.80.150.0 network.
Should I do it?  If yes, how this can be done?
I think it is complicated explanation. If required I can provide diagram.
Any help appreciated
Giuseppe Larosa Mon, 03/01/2010 - 04:27
Hello Zbigniew,
how is the the remote site with IP subnet 10.80.180.0 connected to the MPLS network?
Is it a VRF site in an MPLS L3 VPN service?
if so, what routing protocol is used between the remote site CE and the PE node?
is this happening via the L2 path between the two data centers or via the service provider network?
this would lead to eBGP as PE-CE routing protocol with EIGRP redistributed into BGP.
This is wise and highly recommended because it is likely that you have built two points of mutual redistribution (bidirectional) between BGP and EIGRP.
This would explain the unwanted path taken by return traffic to remote site.
to do this you need to use route-maps and to set a route-tag
example:
site AAA
route-map EIGRPtoBGP permit 10
match ip address 11
set tag 1010
router bgp yourASN
red eigrp XX route-map EIGRPtoBGP
site BBB:
route-map EIGRPtoBGP2 permit 10
match ip address 11
set tag 2020
router bgp yourASN
red eigrp XX route-map EIGRPtoBGP2
this is just an example, your scenario may require further tuning, specially to avoid to advertise unwanted prefixes.
for this reason the use of an access-list or a prefix-list can be helpful to specify what EIGRP prefixes should be redistributed into BGP.
to be noted that you could avoid mutual redistribution by using network commands in router BGP process.
Network command allows in BGP to advertise a prefix if present in the IP routing table not only for connected routes.
I would suggest you to attach a network diagram, configurations of CE routers of DC AAA and DC BBB and of remote site CE router.
Hope to help
Giuseppe
