Are the blades hot-swappable?
Feb 28th, 2010
I have a 4510R switch. i need to upgrade the 100mb ethernet blades to 1gb, can i do this while the unit is on ?.
rob davis
Lei Tian Sun, 02/28/2010 - 05:41
All Catalyst 4500 series switches support hot swapping, which lets you install, remove, replace, and rearrange switching modules without turning off the system power. When the system detects that a switching module has been installed or removed, it runs diagnostic and discovery tests automatically, acknowledges the presence or absence of the module, and resumes system operation with no operator intervention.
Lei Tian
Reza Sharifi Sun, 02/28/2010 - 07:45
Hi Rob,
Even through they are hot swappable, I recommend doing this during an outage window, because you never know what can go wrong.
Related Content
