02-28-2010 08:45 PM - edited 03-06-2019 09:56 AM
Hi all,
i am trying to copy IOS from my TFTP server which is on laptop to cisco 3548xl switch
my curent tftp directory on laptop is c\windows\system32
filename is c3500xl-c3h2s-mz.120-5.WC17.bin
3548XL#copy tftp:
i ran this command
3548XL#copy tftp:\\192.168.1.3_c:\windows\system32\tftp c3500xl-c3h2s-mz.120-5.WC17.bin
Address or name of remote host [192.168.1.50]? 3548xl
Source filename [\\192.168.1.3_c:\windows\system32\tftp]? c3500xl-c3h2s-mz.120-5.WC17.bin
Destination filename [c3500xl-c3h2s-mz.120-5.WC17.bin]?
Accessing tftp://3548xl/c3500xl-c3h2s-mz.120-5.WC17.bin...
%Error opening tftp://3548xl/c3500xl-c3h2s-mz.120-5.WC17.bin (Timed out)
Please help
thanks
mahesh
Solved! Go to Solution.
02-28-2010 09:34 PM
You only have one IOS. You don't need to set the boot statement. I recommend you remove any by using the command "no boot system".
02-28-2010 08:51 PM
The command should be copy tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin flash:
Presuming that your TFTP server is pointing to the main TFTP folder.
02-28-2010 09:06 PM
hi
thanks for reply
i did this
#copy tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin flash:
Accessing tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin...
%Error opening tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin (No such file or directory)
also my tftp server window shows
current directory is c:\windows\system32
02-28-2010 09:16 PM
Can you do the following checks
1.Ping the switch IP address from you laptop in which TFTP is running.
2.check the tftp root directory once again, and the check the file name of the IOS.
3.Finally check weather TFTP server is running properly in your laptop.
regards
karuppu
02-28-2010 09:17 PM
hi,
i tried again here is result
3548XL#copy tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin flash:
Loading c3500xl-c3h2s-mz.120-5.WC17.bin from 192.168.1.3 (via VLAN1): !!O!!O!OOO!OO!OO!OO!OOO
%Error reading tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin (Transfer aborted)
Loading c3500xl-c3h2s-mz.120-5.WC17.bin from 192.168.1.3 (via VLAN1): !!O!!O!OO!OO!OO!OO!OOOOO!OOOOO!
%Error writing flash:/c3500xl-c3h2s-mz.120-5.WC17.bin (No space left on device)************************
this ios is 1.72 mb
3548XL#sh flash
Directory of flash:/
2 -rwx 1645807 Feb 28 1993 21:32:09 c3500XL-c3h2s-mz-120.5.2-XU.bin
3 -rwx 94674 Apr 03 2000 18:53:30 c3500XL-diag-mz-120.5-XU
4 drwx 64 Sep 25 2006 14:40:51 html
7 -rwx 108 Feb 28 1993 21:30:16 info
6 -rwx 556 Feb 28 2010 22:11:24 vlan.dat
113 -rwx 108 Feb 28 1993 21:33:16 info.ver
114 -rwx 3656 Mar 04 1993 06:22:54 s2edcw2a1.txt
8 -rwx 1811155 Sep 25 2006 14:45:03 c3500xl-c3h2s-mz.120-5.wc15.bin
10 -rwx 2588 Feb 21 2010 18:42:34 config.text
9 -rwx 315 Sep 25 2006 14:45:37 env_vars
3612672 bytes total (49152 bytes free)
02-28-2010 09:24 PM
The IOS(c3500xl-c3h2s-mz.120-5.wc15.bin) you want to upgrade it is already present in the flash.
Currently there is no free space is available to upgrade.Moreover if you want to upgrade you have to delete some unncessary files , the try to upload the IOS.
regards
karuppu
02-28-2010 09:25 PM
He's trying to copy WC17.
02-28-2010 09:29 PM
Oh..sorry for the mistake.
Mahesh : try to delete the unwanted fiels in your flash.before that check the IOS version runnning in your switch.
Make the free space and try to upgrade . it should work .
regards
karuppu
02-28-2010 09:12 PM
i tried again
02-28-2010 09:17 PM
You only get "O" when either the link is slow or there's not enough flash space because something else is there.
You need to delete the following files:
Use the command "delete flash:
02-28-2010 09:20 PM
Hi ,
thanks for reply
hi,
this ios is 1.72 mb
3548XL#sh flash
above shows my current flash on switch.
do you know which files i can delete?
02-28-2010 09:32 PM
thanks for great reply
here is what i have done
Loading c3500xl-c3h2s-mz.120-5.WC17.bin from 192.168.1.3 (via VLAN1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 1811552 bytes]
1811552 bytes copied in 66.3 secs (27447 bytes/sec)
3548XL#sh flash
2 -rwx 1811552 Feb 28 2010 22:25:57 c3500xl-c3h2s-mz.120-5.WC17.bin
6 -rwx 556 Feb 28 2010 22:21:36 vlan.dat
3612672 bytes total (1694720 bytes free)
3548XL#delete v?
% Unrecognized command
3548XL#config t
Enter configuration commands, one per line. End with CNTL/Z.
3548XL(config)#boot ?
boothlpr Boot Helper System Image
buffersize Specify the buffer size for filesystem-simulated NVRAM
config-file Configuration File
enable-break Enable Break while booting
helper Helper Image(s)
helper-config-file Helper Configuration File
manual Manual Boot
system System Image
3548XL(config)#boot sys
3548XL(config)#boot system ?
WORD pathlist of boot file(s) ... file1;file2;...
3548XL(config)#boot system file.bin
3548XL(config)#end
3548XL#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]n
3548XL#boot
3548XL#boot sys
3548XL#config t
3548XL(config)#boot sysa
just last step left
under config t
what command should i use
boot system c3500xl-c3h2s-mz.120-5.WC17.bin and then reload?
many thanks
02-28-2010 09:34 PM
02-28-2010 09:41 PM
Many thanks for helping me all the way.
i am all set now
take care
mahesh
02-28-2010 09:43 PM
Thanks for the ratings Mahesh. Glad to be of some assistance.
