GrumpyBear Tue, 03/09/2010 - 11:04
The only way to backup the config on a MARS server is using the "archiving" function to a NFS server or using the "pnexp" command from the command line
racquel.mays Fri, 12/10/2010 - 12:21
So this is how you would backup the MARS appliances entire configuration? Data, incidents, settings, templates, etc.?
