VRF-Lite and NAT between vrf
Mar 1st, 2010
I have two VRF. The first-one connected to Internet, the second-one to an inside LAN with private ip and NAT.
All works but, if I take away the green line, dns resolution doesn't work, every else is ok (tcp, ssh, icmp...). So I need to have two default gateway like in this configuration.
Can you tell me why? I tried this with old and new release of IOS (this is 15.1)
ip vrf reteesterna
rd 1000:100
route-target export 1200:120
route-target import 1201:121
ip vrf reteinterna
rd 1001:101
route-target export 1201:121
route-target import 1200:120
interface FastEthernet0/0
description --- rete interna ---
ip vrf forwarding reteinterna
ip address 192.168.88.1 255.255.255.0
ip nat enable
duplex auto
speed auto
interface FastEthernet0/1
description --- rete esterna ---
ip vrf forwarding reteesterna
ip address 82.85.14.104 255.255.255.224
ip nat enable
duplex auto
speed auto
router bgp 222
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf reteesterna
  no synchronization
  network 82.85.14.96 mask 255.255.255.224
exit-address-family
address-family ipv4 vrf reteinterna
  no synchronization
  network 192.168.88.0
exit-address-family
ip nat pool INTERNET 82.85.14.104 82.85.14.104 netmask 255.255.255.224
ip nat source list 112 pool INTERNET vrf reteinterna overload
ip route vrf reteesterna 0.0.0.0 0.0.0.0 82.85.14.97
ip route vrf reteinterna 0.0.0.0 0.0.0.0 82.85.14.97
access-list 112 permit ip 192.168.88.0 0.0.0.255 any
access-list 114 permit ip any any
regards
Gianrico Fichera
ITESYS SRL
Giuseppe Larosa Fri, 03/05/2010 - 01:41
Hello Gianrico,
if you remove the red default static route do you still see a default route in VRF retetinterna?
because there is no redistribute static under BGP VRF address families so I'm surprised that only  DNS does not work when from VRF reteinterna you try to access internet.
For the way you have configured your device both default static routes should be needed.
Hope  to help
Giuseppe
