First I know that am new to the IP Telephony world I am here asking for advice and help with my problem that am facing if you can guide me to what docoments will be usful I will be more than grateful
am trying to configure a Voice gateway AS5400 to route call from ISDN E1 to to a SIP server, I have configured the dial-peers , but when I try to make a call form , I hear noise like a modem voice I have been reading on Cisco website on this problem and they said all you need is to add the command "incoming called-number ." but still I am hearing the same noise
ISDN E1----------------AS5400 Voice Gateway -----------------------SIP Server
here is my configuration for the dial-peers
dial-peer voice 2 voip
destination-pattern 9T
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
codec g729br8
dial-peer voice 1 pots
direct-inward-dial
port 7/3:D
forward-digits all
if you guys can take a look at it and see if I did something wrong.
you help is highly appreciated
attach the show run
thanks in advance for you
what I am trying to do is configuring a vocie gateway to work as Internatioanl gateway for the internatioanl voice trafic therefor I am using 9T as the destination-pattern
