RME Software Distribution
Answered Question
Mar 1st, 2010
I am looking to deploy IOS code to a couple of 3560's and I want to know how long does the software deployment normally takes.
It's been a while since I used this feature in Ciscoworks.
I also want to know is the command set "snmp-server system-shutdown" needed for LMS to reboot the switches after Software deployment?
Thanks in advance.
Correct Answer by Joe Clarke about 7 years 2 months ago
It really depends.  There are a lot of factors invlovled in a SWIM upgrade (e.g. network latency, image size, protocol used to deploy, etc.).  In general, take the time a manual upgrade would take, and add 20%.  Yes, "snmp-server system-shutdown" is still required for a reboot.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 03/01/2010 - 10:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dionjiles Mon, 03/01/2010 - 10:30
Thanks for the prompt response.....I will take that into consideration.
