VPN tunnel and NAT
Answered Question
Mar 1st, 2010
I have a client that requies a L2L VPN tunnel to be established to secure FTP file transfers, but also don't allow private IP addresses to be sent over VPN tunnel  I have an ASA 8.0.4 available to terminate the VPN tunnel, and my question is, can I terminate the VPN on the outside interface, and still be able to go through the NAT process so I can use the public nat address of the ftp server  to send over the VPN?
For instance lets say I have the following configured.
interface gig 0/0
nameif outside
ip address 172.30.10.1 255.255.255.248
static (DMZ,Outside) X.X.136.20 192.168.1.20<-----FTP server
Tunnel will terminate on 172.30.10.1, but I want to be able to use the X.X.136.20 Ip address for the ACL in my crypto map.  Possible?
Thanks.
Correct Answer by Jon Marshall about 7 years 2 months ago
interface gig 0/0
nameif outside
Thanks.
Ryan
Yes this is perfectly possible. The key thing to note is that in your crypto map access-list you must use the Natted address ie. x.x.136.20 and not the real address ie. 192.168.1.20.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 03/01/2010 - 12:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
interface gig 0/0
nameif outside
Thanks.
Ryan
Jon
