2106 config internal DHCP
Mar 1st, 2010
I have a 2106 controller and two 1520 AP's. One - I'm guessing my "RAP" (?) in Cisco parlance - is hardwired to port 3 of the controller. The controller sees it as an "interface neighbor" with IP address 0.0.0.0 . I'm guessing, this device needs a valid IP address assigned before it will start functioning as an AP. I have attempted to confighure the internal DHCP as described in an application example, but the controller still appears to "not" be assigning an IP address to this AP.
  1. Should I need a DHCP for AP's to function (have entered MAC addresses in Security > AAA > AP Policies)
  2. I see no hooks for the "level 2" / "level 3" activation as described in one of the guides - maybe not an option in the version 6 software?
  3. Any example configurations for a 2106 I could mimic & then tune up for my situation (one RAP and one MAP covering an outdoor area of maybe a couple city blocks, hosting a remote client session from an existing, isolated server)
TIA & Rgds
JR in OH
Scott Fella Sat, 03/06/2010 - 08:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Don't have a config for you, but if you are trying to get your RAP to obtain a dhcp address from the WLC, then you wwill need to make sure the RAP is connected to a port on the WLC that is also on the same vlan as the management/ap manager.  See this thread:
https://supportforums.cisco.com/message/3024233#3024233
If you want to put the RAP on a different VLAN, then I would connect the RAP to a switch not the WLC and makes sure you have a dhcp scope for that vlan.  If the RAP has not joined a WLC, then you can console inot the RAP and assign a static ip address.
Since you are only using one RAP and MAP, it should be fairly simple:)  take a look at some of the Cisco guides out there, here are some:
http://www.ciscosystems.lt/en/US/docs/wireless/access_point/mesh/4.0/deployment/guide/config.html
http://www.ciscosystems.net.ph/en/US/docs/wireless/access_point/1500/quick/guide/ap1500qs.html
Related Content
