How to test ground-start analog lines?
Mar 1st, 2010
Hello, we have ground-start analog lines connecting into our gateway and believe there is an issue with one of the lines.
Is there any good way to test ground-start analog lines?  With loop-start lines I simply use an analog phone to test if an analog line is either good or bad. What can I do for ground-start lines?
Thank you!
Overall Rating: 5 (3 ratings)
paolo bevilacqua Mon, 03/01/2010 - 12:44
  • Hall of Fame,
    Founding Member
With a buttset. A good one can be expensive.
Brian Meade Mon, 03/01/2010 - 13:00
  • Silver, 250 points or more
You have to hook up a buttset then place a ground across the two terminals.
Rob Huffman Tue, 03/02/2010 - 05:45
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ryan,
Just to add another hint to the good tips from Paolo and Brian
If you terminate this line on a standard "surface mount " jack (rj11)
that has accessable "spade tip" style terminals and then plug an Analog
phone into the jack, you should be able to touch a ground to the 'Ring" side
of the line while off-hook to pull dialtone.
Cheers!
Rob
paolo bevilacqua Tue, 03/02/2010 - 06:21
  • Hall of Fame,
    Founding Member
Five stars for you too Rob.
I always wanted to own a buttset but never did
John Huthmaker Mon, 09/24/2012 - 16:22
Turns out the router has FXS cards in it
I'm sending out FXO cards today.
