Tunnel Interface always "line protocol is down"
Mar 1st, 2010
Hello experts,
I am trying to configure a Site-to-site IPSec VPN using tunnel interfaces. I define the tunnel interfaces at both ends, but within the tunnel interfaces' configuration mode, whenever I input the "tunnel mode ipsec ipv4" line the tunnel interface immediately goes down (line protocol is down). I have been following the example located at http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtIPSctm.html#wp1027265 but no luck so far.
When I input the "show ip route" command, since the Tunnel 0 interface is down the remote LAN route does not appear.
I am not that familiar with using Tunnels for IPSec VPNs, so any advice or comment will really be appreciated! Thank you very much in advance! Best regards!
Following one of my router's config:
(831 router with Version 12.4(4)T8 (c831-k9o3y6-mz.124-4.T8), local IP addressing is 192.168.20.0/24, and remote traffic is 192.168.10.0/24; this router is getting internet address using PPPoE via IPCP negotiation, and to avoid problems I have not configured any FW functionality yet).
Current configuration : 3012 bytes
version 12.4
no service pad
hostname MchRemoto1
boot-start-marker
boot-end-marker
enable secret 5 $1$Kuns$rRN78HqUoZlUFBzZKSscE1
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1 192.168.20.3
ip dhcp pool pooldeips
   import all
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
   dns-server 192.168.20.1
   option 150 ip 10.1.1.1
ip cef
no crypto engine software ipsec
username localuser password 0 localpassword
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key L2Lclave hostname <PeerDDNS-resolvedAddress>
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile VTI
set transform-set ESP-3DES-SHA
interface Tunnel1
no ip address
interface Tunnel0
ip address 172.168.0.2 255.255.255.0
tunnel source Dialer1
tunnel destination <PeerInternetAddress>
tunnel protection ipsec profile VTI
interface Ethernet0
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
hold-queue 100 out
interface Ethernet1
no ip address
duplex auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname username
ppp chap password 0 password
ppp pap sent-username username password 0 password
ppp ipcp dns request accept
ppp ipcp wins request
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.10.0 255.255.255.0 Tunnel0
ip http server
no ip http secure-server
ip dns server
ip nat inside source route-map nnat interface Dialer1 overload
access-list 100 deny   ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 100 permit ip 192.168.20.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nnat permit 1
match ip address 100
control-plane
line con 0
no modem enable
transport output all
line aux 0
line vty 0 4
password password
login
transport input all
scheduler max-task-time 5000
end
Trending Topics - Security & Network
