interconectivity with fx?
Answered Question
Mar 1st, 2010
I have some doubts about the what is the best option to integrate an very old TDM pbx without digital options (t1/e1) with a cme.
I used fxo with the pstn, but not with pbx´s.
Can I use fxs ports ?
What are the pros and cons between fxo and fxs?.
Correct Answer by paolo bevilacqua about 7 years 4 months ago
Best would be both fxo and fxs.
Calls always going out fxo to fxs. Otherwise you cannot have one-stage dialing in both directions.
Overall Rating: 4.5 (2 ratings)
Correct Answer
paolo bevilacqua Mon, 03/01/2010 - 13:33
  • Hall of Fame,
    Founding Member
markbatts Tue, 03/02/2010 - 01:32
  • Bronze, 100 points or more
If your old PBX supports it you may want to look at E&M ports.They are the analogue equivalent of QSIG and are( were) used to interconnect PBX's
cheers
Mark
Please rate useful posts
