ip phone support
Answered Question
Mar 1st, 2010
Guys, do you know if cucm 3.3(4) or 3.3(5) actually supports
7961's?
thanks
i can't find any documentation or any device package/ patch / that will show support of 7961s,. 41s on 3.3
thanks
Correct Answer by Jaime Valencia about 7 years 2 months ago
Supported CallManager Versions
The Cisco IP Phone 7961G/7961G-GE and 7941G/7941G-GE firmware release 7.0(3) is supported on these Cisco CallManager versions:
Cisco CallManager version 3.3(5) SR1 or later
Cisco CallManager version 4.0(2) SR2b or later
Cisco CallManager version 4.1(3) SR1 or later
Cisco CallManager Device Packs
You should install the following device packs for these Cisco CallManager versions. You can download the device packs from this location on Cisco.com:
http://www.cisco.com/kobayashi/sw-center/sw-voice.shtml
The device pack readme files provide installation information.
Cisco CallManager Version
Device Pack
3.3(5) SR1
ciscocm.3-3-DevPack-64.exe, or later
4.0(2) SR2b
ciscocm.4-0-DevPack-43.exe, or later
4.1(3) SR1
ciscocm.4-1-DevPack-23.exe, or later
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7961g_7961g-ge_7941g_7941g-ge/firmware/7_0_3/english/release/notes/6141703.html#wp1031083
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 03/01/2010 - 14:03
  • Cisco Employee,
  • Hall of Fame,
    2011
Device Pack
3.3(5) SR1
4.0(2) SR2b
4.1(3) SR1
java
